Are these normal speeds or does my engine need some troubleshooting?
I can't give you any RPM ranges, because my tach doesn't work...
Going downhill, I can get it up to like 86 AT the most, and uphill, around 65-70 or so. And that's at WOT.
It's a 7.3 N/A, and it's all stock as far as I know
It probably needs a timing bump and/or new injector pump and injectors for best performance... but those numbers seem reasonable for a non-turbo IDI. Before I got my turbo, I found that 70 was pushing things a bit.
That's why, for a big power bump, you want to find a used turbo kit, install it and turn the pump up a bit. Really makes a difference, especially at the higher revs.
My N/A will peg the speedo going uphill...though I have a proper y-pipe and cold air intake. Guess I can't remember how she used to drive when stock, lol.
I'd say you should be able to do the same on flat ground, even bone stock, assuming your engine is in good health.
Rob already covered the basics. Timing goes a long way with these engines, and I'd start there.
Received 3,163 Likes
on
it all depends of a few things.
what size tires?
what gear ratio?
what trans?
has your speedometer been calibrated to tire size?
i used a GPS to make sure the speedometer is reading true speed. GPS says 76 when speedo needle is centered on 75
my 88 with C6 trans, 4.10 gears and 37 inch tires has a top speed of 82 MPH, and it takes 3 miles to go from 70 to 82 on flat ground.
what size tires?
what gear ratio?
what trans?
what size tires?
what gear ratio?
what trans?
what size tires?
what gear ratio?
what trans?
on
If you do have 4.10 gearing, you can swap in 3.55 gearing for a very good combo that gives you good efficiency on the highway going 60+MPH.
on
on the front driver side of the engine there is a large nut with two wires coming out of the middle of the nut.
unplug the plug, and remove the nut. this is the tach sensor.
clean it off real good and reinstall it. the tach may start working again.
do not drive the truck too much until you get the tach working properly, the E4od trans needs tach signal to work.
my bet is you are not shifting into overdrive.
Diesel_now
28
02-03-2018 11:34 AM
big ole ford
07-30-2013 09:17 PM
MandRServices1
08-27-2009 10:19 PM
