Stripped transfer case drain plug
Old 06-01-2016, 09:19 AM
Mikeyg76's Avatar
Mikeyg76
Mikeyg76 is offline
Hey guys!
So I got off work today, got under the truck and attempted to undo the fill plug on my 2009 f-150. Needless to say the plug would not budge and it even started to strip, so I stopped, who ever had this truck before tightend the heck out of it! Good thing I listed to someone on this forum recommending to always undo fill plugs first in case you can't get it off! Anyway does anyone know the part number for a new drain plug? And how do you guys suggest I get this dang plug out! Thanks in advance!!!
Mike
Old 06-01-2016, 04:13 PM
Olytlr's Avatar
Olytlr
Olytlr is offline
I haven't looked but is it an Allen head or a hex head? Either one really you can pound on a size smaller socket(12 pt.) or Allen socket and remove the bastage bolts. The pounding of a hammer helps. Also helps to soak them in some Aerokroil overnight.
Old 06-01-2016, 05:59 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
You started to strip the threads or round out the head? The factory uses some red thread sealer to keep it in place and I believe the plug is tapered also. I've never had a problem getting those out of mine so I'm no help there but be careful because the t-case is aluminum and the threads will get messed up long before you damage the threads on the plug.
ETA. I always use just a square head to remove the plugs. I believe it's a 3/8" that fits in the plug perfect.
Old 06-02-2016, 12:34 AM
thzpcs's Avatar
thzpcs
thzpcs is offline
If you stripped the head, easy-outs might be a good idea.
Old 06-03-2016, 12:09 AM
Mikeyg76's Avatar
Mikeyg76
Mikeyg76 is offline
Thanks everyone, I started to round out the hole, put a little blaster on the threads and used a cheater bar and was able remove the plug very carefully. Thanks for everyone's advice!
skyfox10
10-06-2017 01:47 AM
Randy777
07-25-2013 04:35 PM
suthrnslew
22
06-04-2009 05:10 PM
Farmboypowerstroke
08-03-2008 04:25 PM
natewill
04-21-2008 03:34 PM
Quick Reply: Stripped transfer case drain plug
