Help Magnet??
Old Aug 2, 2008 | 06:08 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Help Magnet??
Is there a magnet on the T case drain plug? Where can i buy one?
Old Aug 2, 2008 | 07:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Hell, I think the plug has a magnet on it. When I took mine off it had a magnet on the end of the plug.
Old Aug 2, 2008 | 07:13 PM
Farmboypowerstroke
there isn't a magnet on the plug.
Old Aug 3, 2008 | 01:24 PM
camodown's Avatar
camodown
You have a few ways to do a magnet on the plug. First is to see if the plug is ferrous based (iron). This is magnetizable of course. You can take a screwdriver magnetizer and pass the plug through the magnetizer a few times and it will be magnetized. These can be had for cheap at sears etc. The second way I can think of is to find a small circular magnet wafer thin, cut it to fit inside the drain plug on the outside (dont want to have the magnet fall off inside the case), and glue it down. The third thing you can do, is have a custom iron plug made, it may be common pipe thread, and magnetize it. The problem with that though, is that steel and aluminum slowly react and for a white deposit that can 'weld' the two together...
I would just get a wafer thin magnet and glue it into the hex plug on the outside.
Old Aug 3, 2008 | 03:05 PM
Fraalan's Avatar
Fraalan
There is a donut magnet inside.
It doesnt thread to the plug but it it sizeable and it is all you need.
I had a rare earth on the exterior and moved it when I dropped the pan and saw a black furry donut..
Old Aug 3, 2008 | 03:29 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Transfercase, not transmission.
Old Aug 3, 2008 | 04:24 PM
miller_feed
Thanks Kris.
Old Aug 3, 2008 | 04:25 PM
Fraalan's Avatar
Fraalan
my bad
ignore
