96 5.0 manual to auto trans
Hello all,
I am looking at swapping out my m5odr2 in favour of an automatic transmission. Looking at an aod or aode. Just wondering if all the electrical would be there for the aode or what i would need for the swap. Any recommendations on the trans would be appreciated! Thanks!
on
Is your truck 2wd?
The AOD was continuously upgraded over it's life with better parts so the later the model you start with the better, the '80s models trans and those from cars were particularly weak. the common upgrades include installing wider bands and bigger clutch packs that were found in the 4r70w, a stronger input shaft and a shift kit to eliminate the soft mushy shifts that kill any auto trans. If you buy a core consider just taking it straight to a rebuilder or exchange it for a mail order rebuild, or if you're feeling adventurous buy a kit and do it yourself.. this will require some specialty tools though. https://transmissioncenter.net/produ...gory/ford/aod/
Yes my truck is 2wd.
So what would be the "ideal" aod to start with? One from a 3/4 or 1 ton?
Did some more reading on the jmod, which if im not mistaken only applies to the aode and 4r70w, etc.
But I understand there are some better valve bodies that can be had for the aod.
This sounds like more work than I thought
Maybe Im better off getting my m5odr2 rebuilt? I alsso have an old 4 speed toploader from an old falcon or mustang... Dont know if its any good... Its filthy so Im guessing its not in any better shape!
Thanks Conanski for sharing your knowledge!
on
Prices seem pretty fair... A local shop wants almost 2200 for a rebuilt m5od!! (could probably find one cheaper or get mine rebuilt for a bit less)
Well it gives me something to think about... Thanks for all the info, I appreciate it! I guess Ill keep my eye out for a half ton aod in the meantime...
Blind
10-31-2006 01:53 PM
desperado_18_2000
07-09-2002 02:04 AM
