Hud/wheel bearing
Tell them you have single rear wheels and here is a list of replaceable parts for your rear end. You must decide what needs to be replaced because it's worn, broken, etc:
- Inner wheel seal (x2)
- Inner wheel bearing (x2)
- Outer wheel bearing (x2)
- Rear brake drum (x2)
- Rear brake shoe kit (should have both sides already)
- Brake drum spring kit (1 kit should service both sides)
- Slave cylinder (x2; different part # for each side)
- Rear brake hose (flexible hose goes from axle to frame; one hose serves both sides)
- Axle bolts/lock washers (mine broke off when I reused it)
- Oil resistant silicone/gasket maker (for sealing axle shaft to drum housing)
- Wheel bearing retainer nut (x2)
- Axle shaft
The bearings/cups have a BIN (Bearing Industry Number) stamped on them, what auto parts stores/bearing shops go by.
C7TZ-1239-A .. Outer Wheel Bearing Cup / Bin: LM-104911
C7TZ-1240-A .. Outer Wheel Bearing / BIN: LM-104949
B6T-1243-A .. Inner Wheel Bearing Cup / BIN: 3920
8TH-4221 .. Inner Wheel Bearing / BIN: 3994
I'm in the midst of replacing mine on my drivers rear.
Here are the parts:
Inner wheel bearing
Inner wheel race
Outer wheel bearing set
Rear wheel seal
spindle nut
Hopefully the picture helps. Also I had trouble with oreilly's. Just go to a real parts store like Napa or somewhere where the people behind the counter know things.
Here are the parts:
Inner wheel bearing
Inner wheel race
Rear wheel seal
spindle nut
All of the bearings, races and seals have part numbers on them. You need to pull them and clean them up to find the numbers. The chances of getting inferior parts compared to what is in them is high. Bearings are usually hard to wear out. Especially the USA ones.
Tell us what the problems are youre experiencing and lets see if we can help you get it fixed as well as not buying parts you dont need. Those seals are like $75 each.
Just a correction for somebody's post above a slave cylinder goes on a standard transmission, bur wheel cylinders go on the drum brakes for the rear.
That's just what I've always called them. Master cylinder in the engine compartment, slave cylinder at the wheels.
Dillabough54
06-10-2017 04:41 AM
super 6.8
09-18-2016 11:59 AM
Littlemonster250
05-24-2016 12:00 PM
