Divorced NP203 oil change capacity
Hey everyone. I'm new here and looking forward to learning about my truck. Let's get right to it.
I changed the oil on my divorced NP203 transfer case. The manual said that it would take 9 quarts of oil, but it started flowing out of the fill hole after just 3 quarts. Is there an explanation why or did I do something wrong?
The truck is a 1976 F250 4x4 "Factory Highboy" Regular Cab. Let me know if I'm missing information to make things easier on you.
Thanks in advance.
Thanks in advance.
Welcome to FTE. Did you drain it by taking the rear cover loose at the bottom?
NP203 Transfer Case Specs
NP203 Transfer Case
Good info here about using motor oil versus 90 weight gear oil and or trans fluid. New Process 203 Transfer Case Tech: Off-Road.com
NP203 New Process Transfer Case Diagrams and Information
NP203 Transfer Case
