power steer
I have that style on my 1956 F100. Installed it back in about 1982. That was all that was available. Back then only the pitman arm and a drag link adapter to install the control were available. You sourced your own hardware (control valve, pump, and cylinder) and made whatever brackets and hoses you needed. It works okay. It has a small amount of play in the steering which is normal for that type of control valve. But, you keep the original steering box and column which to me is more important. You shouldn't encounter any fitment issues to sort through with this type of system.
56 power steering
I have that system on my truck works well and fits my application with 427 with factory cast manifolds. I had thought of the toyoda box but it won`t fit with the large cast headers. You must make sure king pins are in good condition as well as the tire rods for the steering to feel right.
Easiest p/s to install and only applies pressure to the tie rods and center link. Allows retaining 3 on the tree and OE horn button without difficult mods. Not as direct as rack and pinion but not much difference compared to a recirculating ball type gear. Was used on tons of Fords, Corvettes, some Chryslers, etc. Nice thing is if something happens to the system you're no worse off than you started as the stock steering gear ratio remains. And it's the closest thing to 'period correct' if that means anything to you.
Other sources for parts,,,,
If you gave a boat yard nearby, look for Mercruser powered boats. They used the same system for powersteering. You can get the valves and adapt them to the draglink. Usually the motors and drives go to hell and they part out the rest of the hulls but don`t always take the steering.
sc63uni
08-20-2007 02:49 PM
sierraben
01-07-2005 08:21 PM
