Re-decking a car trailer
Anyone here had to re-deck their car trailer?
Just wondering what kind of wood you used.
Research shows everyone using everything imaginable, just looking for some first hand experience.
I know a guy who works at a lumberyard and can get anything under the sun, so all options are open.
Depending on the cost, I might go with a 5/4 white oak, but open to ideas.
you are correct ...
I wrote 5/4, I was meaning 9/4
but i'll look into the 2" rough cut too, I would think that would be plenty. I asked the company that made my trailer and they just use standard 2x8 treated.
I'm not that keen on using the new treated lumber though. I don't think it plays well with steel.
Received 6,719 Likes
on
My trailer was built originally for framing lumber, so I put back treated pine 2 x 10's. It's strong and lasts a long time. The trailer was built with one particular piece of steel that I had to remove to do the job, and then weld it back. My trailer was not built with enough space for the thickness of rough cut lumber.
Mine wasn't either, I wanted no lip so I routered the end of the rough cut to fit under that piece on the rear. Now I don't catch the steel lip if I drag something off the trailer. The front one I just cut, raised to fit and rewelded
that's my plan as well, if I go with the rough cut.
the ends of my boards are capped with angle/strap steel, so I'd have to shave the ends to get the caps back on, but then I'd have to lip which would be nice.
there would be a lip at the outside edges though, but I'm not sure that would bother me. I guess if it did, I could get some 1/8" strap and build up the sides to match the rough cut.
I still need to see how much good rough cut lumber costs. Especially in the 18' length I need for the deck.
I called the manufacturer and he said back then (1999) they just used regular 2x8 non-treated lumber. so for it to last this long with regular lumber isn't too shabby.
on
White oak, in particular, is supposed to be one of the best.
If I lived out by your neck of the woods (rapid) id just stop at one of the many lumber mills to the south of you and get what I can find there.
Off topic, but ill be out in Deerfield next week trying to murder a turkey
Admiring my trailer, I am in the same boat. The planks are not totall rotten with stuff falling through.
I was up around Deerfield and points south on Sunday. The hunting should be pretty decent.
flowgoode
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
23
08-11-2013 10:00 AM
jade79
11-02-2010 09:48 AM
afinepoint
24
06-28-2005 08:42 AM
