TS reburn chip & SMOG
I have a TS chip reburned by Tony Wildman, I had him put a stock tune as one of the positions.. My question is, if I put the switch to the stock tune would the smog machine pick it up that I have a Chip/tuner? It's a pain in the butt to remove the chip and drive the truck for a few days before I have it smogged because I disconnected the batteries!!!
Mike
Mike
Assuming you mean California smog, no the machine cannot know if the truck is chipped. The give away would be the switcher and any black smoke from the snap test, when they floor it up to 3k RPM 3 times and check opacity of the exhaust. "Stock" tune should not smoke unless you have other issues. I hide the switcher in the driver side window vent.
If you disconnect the batteries I recommend driving around for awhile before taking it in for the test. There are self-checks done when you re-connect power and take some time to complete and set the flag for a PASS. I made that mistake many years ago with an F-150. Did some work one day and took it in for the test the next and it failed because all the initial diagnostics had not run their course. Now I will drive at least 200 miles to let the diagnostics run their course before having any testing done if I've disconnected the batteries. Haven't had a problem since.
Just unlock your truck, then walk back in the house and put 'em away, then go pull the chip.
So I went back and re-read your post and then
I didn't read it the way you typed it. My mind read it the way you meant it.
Stewart
chrisbrady498
07-07-2014 07:20 AM
jchosler
22
02-28-2010 10:46 AM
trvlintime
Computer Chips & Tuners
09-13-2005 07:31 AM
