Oil sending unit leaking
Old 04-23-2016, 12:20 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
No matter what I do, this thing always seeps... Anyone have this trouble?
351w, dolphin gauges and sending unit. You can see it in this pic if you zoom in
Old 04-23-2016, 12:31 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
I can't tell (because I am to stupid to make it zoom on the computer) but if it is leaking around the threads try pipe dope instead of teflon tape. At least it looks like teflon tape in the photo to me.
Old 04-23-2016, 01:00 PM
jrockdiddy's Avatar
jrockdiddy
I have been using Teflon tape. I'll try the pipe sealant liquid stuff.
Old 04-23-2016, 06:11 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Locktite makes a thread sealant that we used to call liquid death cause it was so hard to undo , but it sealed very well
Old 04-23-2016, 06:23 PM
jrockdiddy's Avatar
jrockdiddy
This look like it?
http://www.all-spec.com/products/56765.html?gclid=CL7E1crzpcwCFZFcfgode3QBLg
Old 04-24-2016, 09:36 AM
CBeav's Avatar
CBeav
CBeav is offline
Permatex advises (at least their rep' that came and held a class at our shop) that both tape and dope should be used together for best seal. The trucks I work on have many air and fluid lines and I don't have time to piddle with not using both. I never have any leaks doing it this way.
Old 04-24-2016, 10:43 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Teflon tape is no a sealant , it is a lubricant that allows the friction fit seal of NPT junctions to thread together enough to seal . If the NPT fitting is cut too small you will need some kind of goop (preferably hardening) to seal it up .
Old 04-24-2016, 11:31 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
The depth of that threaded hole is SHALLOW...if you are having trouble getting a good seal I would look into the possibility that the sending unit is actually bottoming out. The only reason I know about this is because I recently had to rework that hex rod on my 351W to add a sender for my aftermarket oil pressure gauge...the big sender on the end of the rod is an electric fuel pump cutoff switch.
dustyroad
08-06-2019 10:19 AM
dt444e
10-06-2009 03:38 PM
fmc400
07-05-2007 07:05 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
02-09-2005 08:14 AM
gslk1214
02-08-2003 11:57 PM
Quick Reply: Oil sending unit leaking
