Clifford dual intake install
Well as the title says I did it. And it was rather easy. Just an intake swap in my books. Coming from their single carb intake it was relatively easy.
However now I have questions regarding vacuum lines and my massive vacuum leak.
I don't know much about the 38s and my yota guy is out of town, however I only see one spot for vacuum lines. I need three. One ported, two manifold. For Ac/heater controls and brake booster and then distributor.
And I have a big vacuum leak. I'm assuming it's my gasket/headers but I need more info on the webers before I say that's the cause.
Either way, once I had fuel, she spit sputtered and then roared to life with open headers!
Did you install a new intake/header gasket?
It looks like there is a vacuum port on your dual carb intake under each carb ( the ones you've got plugs in ) . Those should give you your manifold vacuum. And if you only want to use one then add a T or a vacuum tree to one of the ports.
But if you have a massive vacuum leak you need to hunt that down before you get into doing any tuning.
I ran the same setup for a while before I recently changed to EFI. Anyway I had good luck using the Remflex gasket, sealed up the intake and exhaust very well. As far as the vacuum lines I used the original vacuum tree from the factory manifold directly into the Clifford manifold. Also make sure to check the float level, mine were not set correctly initially and caused drivability issues until I figured they were wrong.
I have the two big ones plugged yes, and then there's two small ones under the choke. And by that I mean one under each choke.
I have to figure out the brake booster situation. My weber air filters have a big thick white plug that they say connects to the pcv system on toyotas.
I have a lot of stuff to figure out before it runs good. My big vacuum leak is the biggest.
For the ported vacuum you will have to find the port on one of the carbs.
And you really need to consider dumping one of your valve cover breathers and installing a PCV valve.
I tried to, originally and it wasn't enough. It built too much pressure and leaked all over my engine, from bottom sides and top. I wouldn't mind doing a open style pcv type thing to pull from it. And even do it to both. I'll take pictures of the setup the carbs come with and the stuff they give.
I thought the ported vacuum had to be mid level to top of carb and not at the bottom. My Holley had designated lines and sections and such.
Here's a link to a ebay auction to show you what a stock one can look like. There are many different styles out there.
87 93 Ford Mustang Vacuum Distribution Block Tree Brake Booster Intake 5 0 | eBay
Then just install a brass T-block into your intake. Then install one vacuum nipple for the brake booster and another one for your firewall distribution block.
I can't help you with the ported vacuum. The last time I ran a progressive secondary weber carb, I was 16 and it was on a 2.3L in a 79 Mustang. I'm 40 years old now so it's been a while. There is a reason I prefer the simplicity of the Autolite 2100's!!
79super460
10-19-2012 12:39 AM
bruno2
11-13-2011 08:28 AM
