slight issues
Old Aug 27, 2009 | 08:52 PM
hifooy07's Avatar
hifooy07
slight issues
Ive been trying to get some help with this motor but nothing yet. so this is what I have going on.I have a 81 bronco. the straight 6 blew, so I bought a 96 4.9ltr with 80k on it converted it to a carb, with efi exhaust manifolds. running an electric mr. gasket fuel pump, with a mr. gasket fuel pressure regulator at 3psi, if i run higher then that the fuel dumps out the carb(stock 1bbl). i think the carb needs rebuilt but i have a holley 2bbl carb I got for free its list number is 6855 I believe its a 2300 model? I need a adapter for it but dont want to spend $60 for a 2bbl to 1bbl adapter. dont have the money for the clifford or offenhauser intake yet can i get a cheaper one and where? another issue i have is vacuum lines im having a hard time remembering what went were and the diagram on the truck kinda sucks. what vacuum lines do i actually need that wont hurt gas mileage. i have the initial timing set at 10degrees which seems to work pretty well untill i hook up the vacuum advance then it struggles to go up hills and over heats. my vacuum diaphram seems to not adjust so i have another one that does but how do i know what to set it at? seems like its retarded now. if some one could atleast answer a couple questions i would be so greatful ive been struggling with this thing all summer.. thanks.
81 ford bronco, 96 4.9ltr converted to carb and c6 trans.
Old Aug 28, 2009 | 07:40 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
First thing that comes to mind since you asked about vacuum lines is do you have the vacuum advance hooked to manifold vac ( pulls vacuum all the time) or ported vacuum( no vacuum at idle)? Lets start there, should be ported vacuum.
Old Aug 28, 2009 | 10:24 AM
dustybumpers's Avatar
dustybumpers
rebuild kit for that carb is $18. it comes with a new needle and seat, which is what is wrong with your carb. I would not put a 2bbl on that intake, would just leave it stock until I put on a different intake.
Old Aug 28, 2009 | 02:49 PM
hifooy07's Avatar
hifooy07
yes sorry i forgot to mention it is on the ported vacuum. it idles fine when i plug it in to the ported vacuum but sputters horrible at 2500rpm and has no power over heats going up hills, soon as i unplug it, drives fine.
so running a 2bbl to 1bbl adapter wont help at all? i really dont feel like dropping $250 on an intake right now. so maybe ill just rebuild it then.
what about the vacuum lines is that mess of color coded wires needed? or can i just run vacuum to tranny, canister, fuel evap can,distrib, pcv. anything else?
Old Aug 28, 2009 | 03:27 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I'd go on and clean/rebuild the carb as dustybumpers suggested. Make sure you have no vacuum leaks. As far as the vacuum advance, I have a 289 HiPo with a Duraspark that I never have figured out. It will not run right with it connected, but runs fine without it. I finally gave up and just plugged it at the carb. Someone more familiar with that engine will have to help you with the mess.
Old Aug 28, 2009 | 05:07 PM
dustybumpers
this is my 82, mabe it will help.
Old Aug 28, 2009 | 05:17 PM
hifooy07's Avatar
hifooy07
thanks man. not sure what some of the abreviations are though.
Old Aug 29, 2009 | 01:30 PM
Harte3's Avatar
Harte3
All the systems must function properly. Unplugging anything is not a fix for anything. If you are still running the EFI ignition it would probably be best to change to a DS2 system with the carbed set-up.
Old Aug 29, 2009 | 07:42 PM
hifooy07's Avatar
hifooy07
im not running efi anything except exhaust manifolds. its completely converted to carb. i bought a mallory ignition coil though cause mine was bad. i converted a newer motor to go into a older truck. how can i tell the difference between the ds2 and others? im not sure what mine is. its an 81 bronco.
grasfarmr73
30
Apr 7, 2015 04:32 AM
Bwillden24
Dec 20, 2010 10:07 PM
dusty2052000
Mar 20, 2006 09:23 PM
84B_Ron_CO2
Alternative Fuels, Hybrids & Mileage
May 12, 2005 11:26 PM
vanman59
1978 - 1996 Big Bronco
Apr 11, 2003 09:28 AM
