1995 7.5 460 blowing my mind
Ok I have a 1995 f350 4x4 5 speed 460 with 191xxx, I was driving truck home check engine light came on.
Started running super super super rich to the point of blowing black smoke.
I can not pull codes it won't let me code reader won't. Paper clip truck dose nothing. Have 5volts at little plug. Grounded it and still no flash on dash. So I did the stupid thing but only thing I could do at this point I replaced
Plugs wires, TPS,ECT, Air temp sensor, FPR, idle air control, O2 Cleaned air filter. Cleaned throttle body checked everything I can think of still studders at idle. Like its cammed the black smoke has cut down but still present. The truck almost acts like it's missing. I don't know were to go now I have no vacume leaks that I can find. I need to pull codes and I can't I think I have read just about every forum I can find the power point has power everything is right just won't let me see codes please help I need this fixed.
The PCM does not care about the windows.
One out of a truck with an computer controlled automatic transmission would leave the MIL (CEL) lit all the time. You might get by if the donor truck had a C6 transmission and it needs to have the same secondary air system.
Also it must be from a 7.5L truck.
24 Carat
45
02-19-2017 09:46 AM
wahlturfcare
34
08-25-2013 05:00 PM
tmedley
08-23-2010 01:01 PM
strokin'_tatsch
11-12-2009 09:32 PM
