1996 F150 wiring - Ford Truck Enthusiasts Forums
1996 F150 wiring
Old 03-14-2016, 06:07 PM
DairyFarmer5's Avatar
DairyFarmer5
DairyFarmer5 is offline
DairyFarmer5 is starting off with a positive reputation.
1996 F150 wiring
Under the dash near the steering wheel, there is a bundle of wires going up, and I would like to know which one is hot and which one is ground so I can tap a CB radio into it. If anyone could tell me, I would appreciate it!
Old 03-14-2016, 09:05 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
can't answer your question, but I would just tap into the fuse box, either at a hot fuse, or an accessory fuse, depending on your preference. cig lighter is hot all the time if you want to go that route.
Old 03-14-2016, 09:07 PM
joey2fords's Avatar
joey2fords
ground is almost any metal surface you can find under there.
Old 03-14-2016, 10:00 PM
kellen302
kellen302 is offline
kellen302 is starting off with a positive reputation.
I'm using a cig lighter port into the "Power Point" not the ashtray lighter.
At some point when I work up the cajones to clean up the wiring for the auxiliary stuff (Lightbar, headlight relays, etc.) I'll run a dedicated power for it to get a cleaner voltage.
Old 03-15-2016, 05:41 AM
DairyFarmer5
If I tap into the cigarette lighter, won't the CB always be on? I want the CB to only be on when the key is on
Old 03-15-2016, 07:14 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
If you are talking about the wires going into the Ignition switch on top of the column, under the dash down near the floor board then:
Wire A1 (297) a black wire with a light green stripe is the power you are looking for wire.
Wire GND (57) a black wire is ground.
Old 03-15-2016, 07:26 AM
DairyFarmer5
Okay, so with that BLK/LG wire, it would only be on when the ignition is on. Yes?
Old 03-15-2016, 07:45 AM
subford's Avatar
subford
subford is offline
Yes and in both the ACC and the run position of the ignition key tumbler. But not in the start, lock or off position of the ignition key tumbler.
Old 03-15-2016, 02:00 PM
kellen302
I ran my wires to a plug, that plugged into the power point, I can plug/unplug at my leisure and haven't cut open the factory harness as that can turn into trouble if not done properly *Cough*PO of my truck*Cough*
jonrjen
6.7L Power Stroke Diesel
26
10-30-2016 03:03 AM
chucky2
1997-2006 Expedition & Navigator
03-31-2016 08:55 PM
brian1080
02-29-2016 01:32 PM
asmith6
02-01-2016 06:41 PM
shakenbake254
01-05-2016 05:48 PM
Quick Reply: 1996 F150 wiring
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
