EBPV Delete - Gut or Not to Gut Pedestal
I have read both.... some say if you gut the pedestal and remove the guts (actuator and spring) that it will starve the turbo ???
Im doing this tomorrow and really want to know if I should remove all the guts and plug the hole or cut the actuator arm off, reinstall, and plug the hole??? I also know some weld the inlet and outlet oil ports inside but I don't have access to do that in my timeframe so they will stay open.
I plan on keeping the actuator unplugged and fooled with the EVP fooler resistor so the arm will not be active, I just don't know if by removing the actuator guts will the missing mass cause issues with oil volume in the cylinder?
The valve itself in the housing is an exhaust flow restriction.
Just doing the valve delete helps a little with performance but leaves the potentially (or already) leaking actuator in place.
Living where you do, fixing an oil leak and leaving the system in place is likely a wise decision.
I cut and welded my pedestal 12 years ago when I was still south of Duluth si I've got plenty of experience with it gone, warm-ups don't take any longer...
I live just outside Fargo and have never had an EBPV....If you want your truck to warm up faster, drive it instead of letting them sit and idle.
Nicmike
02-23-2020 08:52 AM
Snowseeker
55
06-25-2016 09:10 PM
Groundpounder0331
06-09-2009 10:13 AM
