horn help
horn help
the horn on my 68 f100 has not worked, i picked this truck up in november and now it's time to focus on the horn, with my schematic in hand i have tracked down the problem to the steering wheel, the blue and yellow wire coming from the relay comes into and attaches to the bottom of the plastic cylinder that the contract brush slides into, i can make the horn blow by taking my light tester touch the b and y wire end where it attaches to the plastic cylinder and poke it into the plate behind, horn works great, inspecting the contact brush it looks just fine, now if slide the contact brush back into sleeve clip on to the end of the contact brush and poke the plate behind nothing, now i've been working on this for a bit and am about cross eyed but would i be correct to assume the blue and yellow wire coming into the back of the sleeve has no connection to the metal connector at the base of the sleeve for contact brush to connect to? that can't be because i jambed a wire in the sleeve and ran it to the ground to the battery and horn worked???? knowing that i can ground b and y wire to plate behind and make the horn work it shows steering column is grounded properly correct?
thanks
dave
thanks
dave
My horn was working intermittently. I sanded the contact points on the horn brush and the steering wheel and put a copper BB under the brush, and replaced the ground strap on the rag joint. I tried a different horn.
then I discovered this little guy near the starter solenoid.
It's the horn relay, as you can see it was pretty corroded. Replaced it with a clean salvaged one and all is well.
I may end up rerouting it through a Bosch relay as I have extra room in the box I installed for my headlights, just to clean up the engine bay a tiny bit more.
They get a little tarnished I noticed, the horn on my slick sometimes needed a couple tries to sound off, so I tried the easiest thing first and dressed it on some emery paper. Works like a champ now.
I'm back down to one for now...I found an old 6 volt VW horn in my parts stash the other day and would like to hook that one up as well though. It would scream as long as it didn't burn out.
I thought about mounting the horns closer to the road too, like the old VWs, to project the sound out more rather than into the engine bay. Or, at least pointing the open end of the horn out through a hole in the rad support.
I think hooking up dual horns was the thing that finally pushed that old relay over the edge.
