What next?
Old 02-26-2016, 06:49 PM
green_95's Avatar
green_95
green_95 is offline
What next?
Just got done putting a diamond eye 4 in turbo back straight pipe on, on my 97 7.3. That turbo whistle is sure a head turner as you drive thru town. Got a little work bonus coming up. Was wanting to put it in the truck. The truck is all stock other than the exhaust. I was thinking of getting a ts 6 position chip. But I'm also thinking of getting gauges. Which/what should come next
Old 02-26-2016, 06:56 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
I personally would go with a 6637 intake to compliment the exhaust. It'll make it sound even better! And let her breathe easier too
Old 02-26-2016, 06:57 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,191 Likes on 817 Posts
6637 air filter
Egt gauge
Trans gauge if auto
Custom tune
Old 02-26-2016, 07:02 PM
97-psd's Avatar
97-psd
97-psd is offline
Originally Posted by z31freakify
6637 air filter
Egt gauge
Trans gauge if auto
Custom tune
^^this. Upgrade the intake before getting tunes. Something we have strayed away from is the HPX. It is cheap and easy and helps the truck run smoother. I would add it as you install the intake
Old 02-26-2016, 07:06 PM
green_95's Avatar
green_95
green_95 is offline
It is auto. I do want to get a egt gauge in there. I don't pull or tow anything. Do you think I still should get a Trans gauge and is a boost gauge necessary? I don't want the gauges cluttering things up. Less is good.
z31freakify
Maybe a billet wheel for the turbo. Check turboost.com look for the SPX wheel.
Old 02-26-2016, 08:41 PM
z31freakify
Still good to have. Another thing I forgot is to add a 6.0 transcooler.
Old 02-26-2016, 09:13 PM
97-psd's Avatar
97-psd
97-psd is offline
. He is so smooth. You know what is happening right? You are getting ready to be over run with PMS. Have fun
Old 02-26-2016, 09:18 PM
z31freakify
he just got bit with the mod bug
Old 02-26-2016, 09:21 PM
97-psd's Avatar
97-psd
97-psd is offline
Where does Tugly keep the Buckzooka?
Old 02-26-2016, 09:33 PM
z31freakify
I think on his right shoulder, and right now hes going thru some trouble with Stinky.
Old 02-27-2016, 06:27 AM
green_95's Avatar
green_95
green_95 is offline
That's a safe guess.. lol will be ordering a 6637 intake from riff raff. Is the air filter that comes from riff raff the water proof filter or is it the same one Napa sells?
Old 02-27-2016, 07:26 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
An Edge Insight CTS will do a lot of the things the gauges will do, and a lot of things gauges won't do. It is just a monitoring system that can read every sensor the PCM monitors. But, it will read codes too. You will need to drill and tap one of the manifolds to mount a pyrometer sensor in it for the Edge to read the EGT's. It gets boost pressure from the MAP sensor.
Old 02-27-2016, 08:58 AM
green_95's Avatar
green_95
green_95 is offline
Is a ccv mod required when you do the 6633 intake mod?
Old 02-27-2016, 09:16 AM
CampSpringsJohn
Is a ccv mod required when you do the 6637 intake mod?
No it is not.
Quick Reply: What next?
