1993 F150, 4.9L, E4OD, 2WD: Shifting hard, Speedo out, Cabin light doesn't come on, Alternator.....
Alternator doesn't seem to be charging. (The alternator might be a side issue, I've seen the indicator light pop on once or twice within the previous 3 weeks)
I wandered through the past threads and found a couple possible things. Fuses under the dash are good, I'm about to go outside and double-check the ones underhood, VSS is connected (haven't cleaned the connection,) I haven't pulled the plug on the ABS module (would it work the same if I just disconnected the fuse powering the ABS?)
I'm still doing some looking around to search for possibilities, but if anyone seems to have something, I'll be happy to check it out.
I did just get the truck back from getting the fuel pump replaced. For various reasons I don't want to go into, I won't be going back to that shop. If the PSOM is killed, I'll likely look into getting them to pay for it, but I'll do the troubleshooting.
Thanks for looking
Thanks for looking
