Rounded Nuts
Old Feb 23, 2016 | 07:54 PM
money pit 69's Avatar
money pit 69
Rounded Nuts
I'm down to the torque converter bolts. From what I have read they are nuts.
What size are they we were trying 9/16 12 point. They are rounded off. They were that way didn't do it. I want to leave the converter in.
What are my options for removing them.
1987 F-250 4x4 351w PLEASE HELP thank You David
Does that Gator Grip socket work , grinder,
Old Feb 23, 2016 | 08:10 PM
wag53's Avatar
wag53
http://m.sears.com/craftsman-5-piece...B&gclsrc=aw.ds
Best $20 bucks I have spent, will pull just about any bolt/nut. Lowe's and Advance have similar by Irwin.
Old Feb 23, 2016 | 08:11 PM
PlumCrazy7's Avatar
PlumCrazy7
Snap-on/Mac have specialty sockets for that purpose that have never let me down(have used them in a similar case too). If you don't want to spend the money on those get a 6-point impact socket that is a little small and beat it on with a hammer. Be sure to give the nuts a good soak with pb blaster. A grinder is a sure way to damage the studs, if the above suggestions don't work you may have to resort to a hammer and chisel.
Old Feb 23, 2016 | 08:20 PM
money pit 69
Thx for the reply I saw that Sears tool online. Wondering if it worked. Will try it then go to plan B if not. Are the nuts 9/16 socket size.
Old Feb 23, 2016 | 08:31 PM
Bruners4's Avatar
Bruners4
If there is room to get a small cut-off wheel in there, cut the nut to release the tension on the threaded stud.
Old Feb 23, 2016 | 08:55 PM
wag53's Avatar
wag53
Yes, 9/16, studs are 3/8-24 thread that bolt out will do the job and don't have to worry about hitting threads with cutoff wheel.
KC8QVO
Garage & Workshop
Aug 16, 2018 08:55 AM
my 66
Feb 7, 2014 06:29 AM
ford2go
Garage & Workshop
13
May 20, 2010 12:47 AM
daddio360
General Automotive Discussion
Jul 17, 2006 06:57 PM
Munkey
Garage & Workshop
18
Mar 9, 2005 06:15 PM
