Fuel tank mods
Fuel tank mods
I've got my dad's '91 diesel on the rack and both fuel tanks out because he says he runs out of fuel at approx half tank on both tanks. I figured it was strange that both tanks started acting up within just a few months. Low and behold, the pick-up feet were broke off in both tanks. What's the best way to "improvise" here? I did a mod on my powerstroke where I eliminated the foot but I had to put a filter in line since the strainer screen on the foot was removed. Also...can I do anything on these metal tanks to help it vent so I can fill it faster? Thanks!
Received 3,110 Likes
on
Easy fix:
https://www.ford-trucks.com/forums/1...l#post12907382
Make sure your inner fill vent is present:
https://www.ford-trucks.com/forums/1...-problems.html
I was able to buy replacement pick up feet from Guzzles Diesel O Rings. I need to do a tank vent mod also. I decided that i want to keep the factory vent in place. I found a Dodge tank vent kit from Glacier Diesel Power, p/n 0307-TVK. It has the bulkhead fitting, 90 degree fitting, 3/4" barbed hose fitting and 5' hose. The only modification you need to do is to the Fuel Filler Neck.
