Fuel tank problem
Old May 1, 2016 | 10:32 AM
Biggtruck's Avatar
Biggtruck
Fuel tank problem
I have a 89 d 250 7.3 diesel with dual tanks when I use around 11 to 13 gallons out of each tank the engine will accelerate and die back and and will shut down and will not crank I let it set for couple hours and will start back and go for a mile or so and do it again I can fill them back up and will run fine for 130 miles or so on each tank any help would be greatly appreciated thanks
Old May 1, 2016 | 12:13 PM
mudmagnet63's Avatar
mudmagnet63
Inside the tank is a ( cone of failure ) that will fall off or disintegrate you will have to drop the tanks and add a section of hose th the fuel pick up line to reach the bottom of the tank, its a common problems for our trucks
Old May 1, 2016 | 12:16 PM
mudmagnet63
with pics
https://www.ford-trucks.com/forums/1...l#post12907382
Old May 2, 2016 | 04:42 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome ot FTE. that is a standard problem with these trucks, the pickup tube in the tank tends to crack between 1/4 and 1/2 tank, and then suck air when the fuel level gets below the crack.
most of us just live with it and keep the fuel tanks over 1/2 full. others drop the tanks and repair or replace the pickups.
Old May 2, 2016 | 04:49 PM
tankguy's Avatar
tankguy
We top our tanks off at around 100 miles.
d-day
Dec 9, 2014 08:40 AM
Nobody39
Oct 31, 2014 02:45 PM
MFW
Mar 8, 2014 07:53 PM
jim hataway
Aug 25, 2004 07:42 PM
