96 m5r2 rwd swap into 88 m5r2 4x4?
Old 01-30-2016, 05:41 PM
cano4574's Avatar
cano4574
cano4574 is offline
I have an 88 f150 4x4 that had a m5r2 five speed in it, I removed and sold the tranny transfer case and driveshafts. Now I got a 96 f150 with an m5r2 and rwd. I need to know if the tranny and driveshaft will install in the 88 so I can drive the 88. The 96 has a messed up frame.
Old 01-30-2016, 06:16 PM
Conanski's Avatar
Conanski
Conanski is offline
Yes it's a direct transfer.
Old 01-30-2016, 06:19 PM
cano4574's Avatar
cano4574
cano4574 is offline
Awesome. Thanks
Old 01-30-2016, 07:38 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
I hope they are the same wheel base, so you can use the drive shaft.
Old 01-30-2016, 07:40 PM
cano4574's Avatar
cano4574
cano4574 is offline
They are the same wheelbase 133"
Old 01-30-2016, 07:41 PM
JRS2's Avatar
JRS2
JRS2 is offline
I thought you would have issues if one was a 2wd and one was a 4 wd ....
Old 01-30-2016, 09:45 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
You can't put a 2WD trans in front of a transfer case, but he's basically converting the truck to 2WD if I understand correctly.
The only thing I'd be concerned about is the transmission crossmember, and even if that's an issue it doesn't seem like it would be insurmountable.
Old 01-30-2016, 10:02 PM
cano4574's Avatar
cano4574
cano4574 is offline
That's what I'm doing until I can find another cheap 4x4 donor truck.
Old 01-31-2016, 07:35 AM
JRS2's Avatar
JRS2
JRS2 is offline
Ok, I am now following ..... after driving up north in a fair amount of snow know that I personnally would never do this - go back to 2 wd ....
Old 01-31-2016, 06:14 PM
rock15t's Avatar
rock15t
rock15t is offline
Isn't the vehicle speed sensor on the transmission or transfer case on the 87-91? The 96 would use the vss on the rear axle, correct?
charliechaindrive
13
06-23-2015 12:02 AM
44dwarf
05-07-2008 08:53 PM
ANTIDodge
1983 - 2012 Ranger & B-Series
10-21-2006 11:44 PM
Quick Reply: 96 m5r2 rwd swap into 88 m5r2 4x4?
