What's going on here
Old Jan 31, 2016 | 02:37 PM
rbr658's Avatar
rbr658
Unhappy What's going on here
I have recently had around $1500 of work done on my 94 F 150 5.8L. Tune up, injector service, PCV and idle control valves, oxygen sensor, etc. (tune up components also). Still idles rough but smooths out when up to speed but on occasion will stall at a stop. Has 177K OM and had stuff done that had probably never been done in 21 yrs. With the idle the way it is I have had the truck stay in second and then will surge and slam into higher gears (this is intermittent). Mechanic is kind of stumped with diagnosis. I would appreciate some thoughts on this please.
Old Jan 31, 2016 | 02:54 PM
khadma's Avatar
khadma
Carpenter Local 745
Look/listen for an upper air intake leak or take it to a shop that can do a smoke test for you.
Old Jan 31, 2016 | 03:41 PM
subford's Avatar
subford
You need to get the self-test ran and see what it says in KOEO & CM.
But sounds like an EGR valve sticking open and maybe a bad VSS input to the PCM Computer.
Old Jan 31, 2016 | 05:21 PM
valkyrie9901's Avatar
valkyrie9901
Coffee can vacuum got a rust hole in it?
Old Jan 31, 2016 | 05:59 PM
rbohm's Avatar
rbohm
i agree with the others, a vacuum leak is the first thing i would suspect. and it can come from a variety of sources, from intake gaskets leaking to vacuum hoses failing, etc.
the other thing i would look at with modern vehicles especially is electrical connections, and grounds, grounds, grounds. these can also cause similar systems issues.
Old Jan 31, 2016 | 06:40 PM
The_Drew's Avatar
The_Drew
Also TPS couldn't hurt
cryptyx
Sep 29, 2014 08:27 AM
bkbkbkbk
Aug 25, 2014 06:30 PM
wolverine382
1997 - 2003 F150
Apr 21, 2009 10:13 PM
moosetrax
Nov 22, 2007 01:25 PM
DelDiesel
Mar 9, 2007 08:30 AM
