I lost my key fob. Ordered 2 off ebay and programmed then with no problem, almost. The key fobs work perfect but the keypad on the door doesnt work anymore. I went through the steps to program the fob again and still nothing. Is there a way to program the keypad again? I know the factory code.
Program the keyless entry with your fabs. Program the fabs first and before it times out out your code in the keyless entry and then it should honk just like when you programmed your fabs
