strange overheat
strange overheat
Truck runs cool when driving around town about 177. Get on the highway and the temp goes to about 195, go up a mountain pass she climbs to about 210 and I feel that If I dont back off the gas the truck will overheat because the temp just keeps climbing. Go down the highway again on a flat stretch of highway and it drops to 195, get into town temp drops to 177 and even lower when i just let the truck idle. truck has a brand new 195 thermostat, fan clutch is only a month old, water pump is about 2 years old, this truck has had head gasket issues in the past but every year I put in the bars stuff and have not had a problem with it since, I started doing the bars stuff about 4 years ago. This is the stuff you flush the system first with not the pour in stuff. 1997 f150 4.6l
you have a 195 degree thermostat. It would not be abnormal to go to 210 when climbing a hill. If it never stopped climbing that would be different. You may not have a real problem, or the long term use of BARS may be effecting you a little bit. I don't see a big problem with you present readings.
eddieruns
09-05-2013 10:51 AM
AC94EXPLORER
06-07-2009 08:58 AM
andym
08-23-2004 01:02 AM
