Ruined Dana 60
Looks like it was a little low on oil if the pinion is all rusty.
Chipped teeth on R&P of a GM 10 bolt in a K5 Blazer because carrier bearings went bad.
I also ran it low on oil and heated the housing to turn it white but the gears did not look rusty like your pinion does.
Had a buddy put spider gears thru housing on a Dana 44 front in this jeep but he was racing it off road at the time.
Funny you say about rear lock up. My sons YJ did that going down the road slid it sideways across both lanes and could not move it. He was lucky it did not flip or someone hit him as it was night time and no lights on that road.
Dave ----
Dave ----
Even driving with the hubs locked and in 4WD at high speeds isn't a problem in and of itself. Although you've got to question the wisdom of driving 70 mph in conditions that require 4WD. And that's what the sticker is most concerned about, people getting in a wreck and claiming Ford designed a faulty vehicle that wouldn't stay upright and on the road when driven 70 mph in a blinding snow storm.
But none of this is applicable to this thread anyway because as 82F100SWB said, this is a rear axle.
I'm looking at this on my phone, but that first pic appears like the front of the case got *really* hot.
Hard to tell what blew through the case since there are no guts in it, but it must have been a BIG bang.
My carrier split on the highway and I thought I'd hit a cinder block.
The case was still in one piece, and I drove home on the front wheels.
This not a joke.
Joke = "horse walks into a bar and the bartender says, why the long face"
Broken Bullnoses are never a joke.
The pinion head got so hot it burned the oil off. I'll take a better picture of it, but the pinion twisted right at the inner bearing. I had been on the highway for more than twenty minutes. From exit 81 to exit 95 of I94. (Michigan). At 95 it acted like I lost 5th, put it in fourth and somhow drove to exit 100. Letting off the throttle it clunken and made tge grinding noise. At the bottom of the ramp I looked under to find a smoking dana 60 with the flid pouring out the bottom. 4wd got me to my shop. It did not like driving or moving with that broken pinion sitting where it was. But I made it.
Futher inspection today found the driverside brake drum coated in lube. I knew the pinion seal was leaking but I kept oil in it. So low fluid in the culprit, but I've seen an axke detonate under normal usage.
rottenstock
07-10-2013 02:19 PM
fordsgofaster
05-23-2010 03:26 PM
