01 4R70W help
01 4R70W help
Hey guys I'm needing some help. I have a 2001 F-150 4.6l 4x4 with the 4R70W. Recently my trans went out. I contacted a local trans shop that told me that depending on whether my truck was a true 2001 depends on what year of transmission I could use. I have contacted numerous junk yards and transmission shops and dealerships and no can tell me how to tell the difference. The trans shop said if it was a true 01 that only a 01-04 would work and that if it is a early 01 a 2000 down will work but said he couldn't tell me which it took unless he tore into it. Is there a way to tell which one I have? Thanks in advance for your answers!!
Look at your ID decal and get the production date. also you can go to
FordEtis home page
and select the vehicle tab, enter your vin and get your build sheet for your rig.
FordEtis home page
....I just ran mine and it says the below info....Mine is also a 2001 and I def have the 4R70W.
16.01.2001
Vehicle Line: F150
Body Style: Double Cab (3/4 Door)
Version: 150
Engine: 5.4L Modular SOHC V8
Transmission: 4R70W (AODE) 4-Speed Auto Trans
Drive: LHD 4WD (PTD)
Axle Ratio: 3.55
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"
Paint: Deep Wedgewood Blue
16.01.2001
Vehicle Line: F150
Version: 150
Axle Ratio: 3.55
Territory: (+)"USA"
canister
12-01-2009 03:41 PM
FutureBiodieseler
08-02-2009 10:45 PM
