I have seen a few threads on here talking about a mech. diode in the trans. of the 01. I was wondering what is this and why is it bad. My truck had a rebuilt trans in it when i bought it and wondering if you could tell if it still had this. You wouldn't think they would put something bad back in the truck.
Have a look here at the TSB. If you need help with the dataplate for build date let me know. First is year, second is month via letter, and third is date of month. If it was rebuilt you have no way of knowing if the intermediate assembly was replaced. The retro conversion or diode fix costs about $250 just for the parts. So if the diode was not failing, it may not have been replaced.
Do these go out at random or do they normally last a certain amount of miles? My trucks build date is 01/01 so it did have one from the factory. I am guessing that they replaced it because I haven't had any troubles for the 30,000 or so miles that I have had the truck.
They do go out in random but usually within 100,000 or near there. The diode is a three part device ( I believe ) that somehow allows the trans to shift up or down. It looks like a ring that slips into another ring then into a housing ring so to speak. I,m no trans mechanic but just went through this last week. The inner ring has a slight shoulder on it and mine was missing half of this shoulder and took out a few other items BUT I didnt drive it much once I realized what my trans was doing so major damage was slight. I needed a new assembly set (77.00 ) a filter,set of pump gears (26.00 ), drum conversion diode kit (219.00 ) then I desided to do the torque converter ( 325.00 ) and a tugger kit (127.00 ) which I am VERY PLEASED with. Whole job was 1450.00 with fluid, labor, parts . My trans has never shifted so good, I mean its unreal compared to stock, it is SMOOTH, solid and I was told should pull a house if needed. ALSO I am going to instally myself a additional trans cooler to eliminate heat better which is recommended in the 01 such as mine.
Clint40, Did you have a dealer perform the work or some independant? That far along and I might be thinking of a BTS tranny. I need to find my build date first.
Clint40, you should also think about installing a transmision filter on the return line from the cooler just in case there's a few shrapnel pieces that didn't get flushed out. It would definitely be a buzz kill if something happened to the new one. The one Ford recommends with every rebuild is just a Magnafine. For $15-$20 it's cheap insurance.
They rebuilt plenty of them with the same parts lousy parts in the early days. That was before they figured out ( decided to do something ) intermediate-one way clutch, brake drum and clutch plates and the associated parts.
If your transmission was rebuilt in the last 2-3 yrs, you're more than likely okay. If you start getting funky shifting especially involving second gear or low gear when you mash on it, you might want to investigate it further.
Other than that, keep up on the maintenance and enjoy it.
I had an independent do mine ( Sure Shift Transmissions of Kawkawlin Michigan) and I highly recommend him. Brian is the owner and has had 25 years of nothing buy trannys and does an HONEST and PROFESSIONAL job. He and I raced against each other many years ago on the local roundy round track and was recommended to me by many people before I made my decission to get it done there. He has done many of these fords for local construction companys and so on and knew excatly what I needed when I bought it in for a test drive. I delivered it on a Monday and it was done on the friday of the same week. My trans shifts so nice know that if you guys were to try it you would have your done just because , whether it needed it or not.
You need to look at the tranny data plate on the side of the tranny for the build date, not your truck build date as they differ. The tranny is likely to have been built prior to the truck build date unless it has been replaced.
When I rebuilt my trans at 128k, the mechanical diode was still in good shape. The center support bearing, for the rear of the overdrive planetary, came apart. This little $9 bearing was the cause of my trans woes. The "diode" is a ratchet type one-way clutch and the replacement is a sprag type. I had to replace the direct clutch drum also to retrofit the clutch. But, I saw recently, there is now a replacement for the "diode" that allows you to reuse the original drum. This saves you a couple of $100.
I beefed up my trans with more and a better grade of clutches, 300M input shaft, and a triple disc billet converter. I also installed the TransGo reprogramming and converter lock-up kits.
