Pulling L when braking question
I have a '99 F350 w/ over 200k Kms. I don't drive it that much. This past summer I noticed when braking it got stuck and would pull to the left. I would have to pump several times to release it.
Got to a shop who said my left caliper, pad and rotor were done, maybe got stuck closed. Both front calipers and rotors were replaced. When they were done, I noticed the truck was pulling to the left when braking. Took it back, they said everything was fine and maybe needed a front end alignment. The steering was fine when driving in a straight line.
Took it to Ford shop who did document the problem (front left caliper closing more than right) and said I probably need a new master brake cylinder. Did not have that done, took it back to original shop who said that didn't make sense because the brake cylinder does not regulate "left vs right" instead, the entire brake system would go out.
They then replaced both calipers under warranty (i think because ford dealer documented problem). I'm still noticing the same problem under certain driving conditions.
Does it now make sense that I do need a new master break cylinder? Could this effect the front left more than the front right? Anything else anybody can think of? Thanks.
OK, thanks, sounds like I'll eliminate the M/C.
I don't think the rear breaks have been checked for this issue because when it does happen, it is such a sharp turn to the left. I didn't think the rear breaks could be causing this.
It' doesn't happen 100% of the time, of course.
Thanks for the thoughts, everyone. I'll have the rubber hoses checked, and the rear breaks. Glad to hear it's probably not a M/C issue.
Thanks again.
Thanks again.
Like mentioned above, check the rear brakes. Might be a bad rear caliper.
I know you have disc brakes, but on my old 96 F350 with drum brakes, I had a noticeable, but not severe, pull to the left when braking. When I inspected the rear brakes, I found that I had installed the right side star wheel in backwards. Each time I backed up, it would loosen up the right brake star wheel. It was then applying more left brake pressure than the right side and would pull to the left.
an update
I forgot to post an update:
I took the truck to another brake specialist. After a long inspection, they decided to try to check if brake fluid was making it to both front calipers. When they unplugged the front right one, no fluid came out. Their theory was that when the front calipers were replaced, it was not bled properly and only air was getting to the front right caliper. If that wasn't the case, the only other option was replacing the master brake cylinder, even though they didn't know how that could direct fluid to the front left, but not front right.
They bled and filled up the brake system again. Sure enough, a few weeks later, the truck is leaning to the left again.
I haven't taken it back yet because of my schedule and I don't use it that much during this time of year.
I'll post an update when I do take it back.
I'm not sure how, why, or what, but when I put new stainless flex lines on my Excursion the right front would not bleed. I was underneath it and my buddy said he had to STAND on the brake pedal as hard as he could - pulling the wheel with both hands - and no fluid was coming out except a dribble. I had the bleeder completely off the caliper. Finally after 3-4 hard pumps a huge spurt of brake fluid shot out and it was fine after that.
I used to work in a brake shop and I've bled a LOT of brakes. Never seen anything like that before.
From what I understand ... what he told you doesn't make sense. Bleeding the brakes is not done through gravity ... it is done using brake pedal pressure (pumping). So, not sure how some ups and downs in the hard brake line will make it harder to bleed ... unless I'm missing something.
ToledoFire
03-15-2007 02:49 PM
xdiver
10-02-2003 02:03 PM
