aftermarket seat height
Hey everyone.
Going to figure out the seating stuff soon and was wondering what people ended up with if they used a bucket style seat. I know I might get, "whatever you're comfortable with" but thought I'd ask.
I'm about 5' 10" and just sitting on objects at certain heights seems like a tight area to use the pedals if the seats are lower.
For me the solution was to get seats that had relatively thin backs and then push them backwards as far as possible. And then furthermore to rework the firewall to push the pedals away from me. But for most folks this is probably excessive. And I'm a bit OCD about ergonomics to be honest.
At least you're thinking about this now, as opposed to after it's all built.
That's a good observation, and has been my experience also. As you lower the seat you start to get scrunched up relative to the pedals.
I'm doing the same thing. Stock height, at the very front of the seat is approx. 13 inches. However, that is misleading as most newer seats are not nearly as generous in the seating area. I have found about 10 inches, seat bottom to floor, is good.
Buying the buckets you have shown will require some kind of adjustable seat bracket. Speedway sells a universal one that looks pretty good. However, the total height is only 7 inches, (about the same as most modern buckets). You will still need to lift the seat some more. And if you are installing a console, you need to keep its height in mind too.
I am looking at what I am calling a "false floor". Take your lead from some of the examples in the various builds here in the forum. Box tube and heavy sheet steel seem to be the norm. Use the original mounting holes to mount the false floor then build your new floor to match your new seat brackets.
Don't forget, even with the original tank, once you get the seat above the bottom 4 inches, the tank starts to allow for more rearward adjustment.
theGman
21
08-15-2006 12:16 PM
