'07 seats help
Old May 7, 2007 | 09:23 AM
WayniacKT's Avatar
WayniacKT
'07 seats help
My 07 Sport is almost perfect, but...
The seats are too tall (or I am) and my head keeps rubbing against the headliner. This happens especially since the headliner has about a 3/4" lower section going right thru the middle of the roof (not sure why).
I have tried to just drive with the seat back more, but that is just starting to hurt my already screwed up back.
So I was thinking perhaps some aftermarket seats may help.
Dose anyone know a way I can lower the seats, or where I might find some reasonable custom aftermarke seats that would fit my 07?
thx.
Wayniac
Old May 7, 2007 | 09:46 AM
RangerPilot's Avatar
RangerPilot
Wow...how tall are you? I'm 6'1" and still have clearance between my head and the roof. Not a ton, but enough.
I don't know of, nor can I see any way to, lower the stock seats. They are merely a seat frame on the sliding frame bolted to the floor, so nothing that you can take out to lower it.
I'm not sure of any seats being available that are custom made for the Ranger, but you can check places like eBay and call around and ask. If you have a regular cab, one of the issues will be will the seat fit from front to back without hitting the back window.
Hope you find a solution.
Old May 7, 2007 | 09:52 AM
john112deere's Avatar
john112deere
Well, I can tell ya that the driver's seat in my truck sits a LOT lower than the passengers side.... Guess 235k miles with usually just the driver will do that.
My mother, who isn't very tall, had small lift blocks installed under the back of the seat in her Explorer to make it more comfortable for her to drive (absolutely KILLED my back from then on) at a shop that made most of their money refitting vehicles for handicapped people to drive. Might look around for a similar place in your area, and go talk to them.
I'm wondering if your best bet may be to have the foam replaced with a thinner piece, but I don't know.
Old May 7, 2007 | 10:14 AM
RangerPilot
My driver's seat also sits a good bit lower than my passenger seat. When I was converting to bucket seats I switched my driver and passenger seat and sat a good inch higher. Switched back, didn't like it.
Old May 7, 2007 | 07:45 PM
toolman1010's Avatar
toolman1010
Might try a custom seat shop in/around your area, had mine repaired at one and the cost was not too bad
