1993 F350 5.8L EGR High Voltage
I have a 1993 F350 crew-cab 5.8L with C6, 4WD SRW. This truck is retired Navy - was a plow truck on a Navy base in Rhode Island. In fact, it has a low-pressure by-pass oil filter installed by the Navy. Its been a bit neglected over the years and I put a lot of basic maintenance into it - its been a challenge but useful and fun.
I have an interesting observation about my replacement EGR valve. When I bought the truck in Feb 2014 the original vacuum lines were in pretty bad shape. Based on what I read in a forum I replaced most of the original nylon vacuum lines with 5/16 rubber vacuum lines. I started having EGR issues and decided that the rubber line dampened the vacuum signal between the EGR solenoid and the EVP sensor. I replaced this line with a hard nylon line - solved the problem. In the course of investigating the EGR problem I discovered that the original EGR valve wouldn't hold a vacuum according to specs. I replaced it with a new EGR - my troubles worsened. I began having a high EGR voltage code (334 - KOEO) and while driving would get 334, 172, 332 and 334 and no power on load. I check the EVP sensor and decided to replace it because the resistance (EVP-->Vref and EVP-->SigRtn) were out of spec while mounted on the EGR valve. I purchased a new EVP sensor. On the bench I measured 4300 ohms EVP-->Vref. When I installed onto the EGR valve now I got 2300 ohms. Turns out to seat the EVP sensor on top of the EGR valve the sensor rod on the EVP was compressed by about a quarter of an inch on the new EGR valve. I think this was the source of my 334 code. With the EGR valve closed and seated on the new EGR valve I was starting out with about half my resistance range gone. I assume since the resistance was already 60% gone while the EGR was closed my return voltage was too high. I pulled out the original EGR valve and installed the new EVP sensor on it and the sensor rod was barely compressed. I measured the height inside both EGR valves and the new valve is about a quarter of an inch shorter. As far as I can tell the new EGR valve and EVP sensor are supposed to be the proper parts for this application.
My solution for now is that I have reinstalled the original EGR valve (with slow vacuum leak) - all my codes have disappeared.
Has anyone else observed this with a newer EGR valve? or an I missing something.
Thanks very much.
Doc TeeRay
Thanks very much.
Doc TeeRay
Welcome to FTE, please stick around. Actual technicians who diagnose & repair are few & far between & it looks like You don't fool around. Working on making an EGR function correctly is a rarity too.
I have no direct experience with your observations, but possibly someone has noticed. Was the replacement Motorcraft unit or parts store aftermarket?
Once again welcome & does the truck carry the Navy livery? (we love pics)
I'm a Motorcraft "where ever available & not excessive priced" kind of guy, followed by orig parts manufacturer (like Bosch, Siemens, etc) & then BWD & store stock last. I also have no problem using JY stock stuff & stockpile it when possible for pennies on the dollar. The aftermarket has a lot of slop built in regardless of country of origin & is always a crap shoot as far as function & durability.
I suggest a Motorcraft one if available.
My local dealer gives me a discount because I usually walk in with the part number in hand. It saves them time and I am a return customer because they are willing to work with me.
WWW.HORIZONPARTSGUY.COM
I get my part# here, get price + shipping & sometimes my dealer will beat it & if not I place my order.
ravens fan
03-21-2013 08:26 AM
F TOO FITTY
02-25-2007 09:44 PM
