1987 F250 460 Possible Timing Issue?
Hey all, I recently bought a 1987 F250 4X4 Extended Cab 460 Auto for cheap. The guy I bought it from said it just stopped running one day and that he figured (somehow) that it was a spark problem. When I got the truck the engine was taken down to the timing chain which was replaced and not yet run.
I put the engine back together and diagnosed that no fuel pumps work (which I assume was his original problem). I replaced the front tank's pump and it is working as it should now. All I get when I turn it over is backfires through the carb. It wants to fire right up, but backfires and I obviously stop cranking.
I double checked my timing. Cylinder 1 at TDC, balancer where it should be and the rotor is pointing at #1 plug wire. I then triple checked my firing order from the intake and added electric grease to both ends of the plug wires. It does feel like it wants to start right up but backfires through the carb.
I guess what I'm wondering is if there is anything else that can cause this other than what I suspect -- the timing chain being off a tooth. What else would you all check before tearing the front of the engine off again?
don't just hold your hand over the hole, plug the hole with your finger and you will know if your getting compression or not. Also have you checked the whole engines compression?
TheTinian
03-08-2008 06:59 AM
fasch74
12-02-2003 12:23 AM
