360 timing problem
Old Mar 7, 2008 | 11:17 AM
TheTinian's Avatar
TheTinian
360 timing problem
I was heading out to the woods the other nite, and my truck just died in the middle of the road. I was able to get it to start, but it was running like **** and limped it out to the woods. Once i got out there i shut it off and could not get it started again. I figured it was my carb. So i went and got it rebuilt, put it on only to find out it aws doing the same damn thing. We figured out the timing was off... The first thing i check was the distributor, but it as tight. So the only other thing would be the timing chain, right? I have tore into it yet, but im guessing that is must have slack in it and skipped a tooth. Any other ideas?
Old Mar 7, 2008 | 11:36 AM
Redmanbob's Avatar
Redmanbob
If it is timing it would show via the damper @ 0 (TDC-not 180º out)and position of the rotor. If it shows up out of position you could drop the fuel pump to have a peek at the timing chain slack without removing all the engine face to get at it.
Old Mar 7, 2008 | 12:19 PM
ramarado's Avatar
ramarado
Must be the day for it on 360's. Mine did pretty much the same thing today. Was running perfect then all of a sudden started sputtering and wanting to die. When I tried to restart, it took forever to get it going and gave all indications of being fuel. Finally got it restarted and it ran perfect again for a while then started doing it again, and died Long story short, now can not get it to start. Thought it was coil, new one makes no difference, gas down carb, no difference, checked and seems to not be getting fire to plug wire. Any ideas? Haven't checked to see if I'm getting fire to the coil, but don't know where the coil gets it's fire from.
Old Mar 7, 2008 | 12:28 PM
Mike G's Avatar
Mike G
Points?
Sounds like neither of you are getting spark to fire the juice off.
--Mike
Old Mar 7, 2008 | 01:32 PM
FitchBanjos's Avatar
FitchBanjos
Bad gas ? Maybe some water in it ?
Old Mar 7, 2008 | 01:46 PM
85e150's Avatar
85e150
Timing chain check method:
Remove dist. cap, move crank by hand until the rotor moves. Reverse rotation by hand and note how far you move the crank before the rotor moves. Shouldn't move too far. I think they will jump at anything over 1/8th turn, maybe, could be.
Old Mar 8, 2008 | 06:59 AM
TheTinian's Avatar
TheTinian
Mine had plenty of spark though. It isnt an issue of gas, or spark i checked all that. We re-set the timing and it runs perfect now.
idahofordguy
Sep 6, 2008 10:32 PM
ncheavymetal
Jul 24, 2008 10:12 PM
shaggymane
Jun 16, 2004 10:43 AM
Coasty
Oct 20, 2002 11:45 PM
