Need help figuring out a short to the starter
I'm tring to figure out a short to the starter on my sons 1995 Cadillac Deville.I would post on the Cadillac forum but it seems like most Cadillac guys just take it to thier mechanic.
Got a good battery and a new starter, when my son put in the new starter he connecter both the positive wire and the wire to the neutral safety switch to the same terminal.ipulled the starter back out, had it tested and put it back in correctly.if you try to crank it it blows the fifty amp starter fuse immideatly. If you jumper it from the ignition post on the starter directly to the battery while someone turns the key, it cranks over but wont tart.Any thoughts? Thanks in advance!
Received 3,108 Likes
on
I'm having a hard time figuring out why that would blow the fuse unless it had a bad solenoid. The battery cable goes to the outboard large terminal, the strap from the starter motor housing goes to the inboard large terminal, and the NSS wire goes to the small terminal marked "S". Something isn't right here.
on
02GrayPowerStroke
1997 - 2003 F150
07-11-2015 10:17 PM
wporter4671
05-25-2009 09:42 PM
