1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Which brand transmission jack to buy? Also any advice on pulling the transmission?
Old 11-05-2015, 04:30 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
I am getting ready to swap the transmission in my dads 250 v-10 4x4. Any suggestions to which would be a good jack to buy and use for the swap. Would like the jack to be able to pull the tranny in my 7.3 4x4 is that time comes also.
Also with the v-10 transmission, any suggestions as to write ups? Advice? Etc?
Old 11-05-2015, 06:14 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
If you tell is what year, we'll know which transmission you have.
Old 11-05-2015, 06:21 PM
Firefighter 1406
That sure would be helpful now wouldn't it.
It's a 2000 auto with the v-10. 4x4.
Old 11-05-2015, 07:51 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Try to find a high lift version, so you don't have to set it up on hunks of 4x4's to reach the bottom of the trans when it's in the truck.
Old 11-05-2015, 08:53 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Check out harbor freight, i have their three ton jack for about five years now and last year bought their four ton jack with outriggers and I LOVE THEM! My four ton lifts up our two (empty) home heating oil fuel trucks so i can do brakes, tire rotations etc on them with little to no effort. Harbor freight makes a tranny jack that almost identical to the three ton i have except it has a nice top with adjustible mounts so you can hook the trans to it, get a coupon online and buy it for under 100BUCKS
Old 11-06-2015, 07:08 AM
Firefighter 1406
I have a harbor freight in town. Will go check this out.
Old 11-07-2015, 08:17 AM
The Bone's Avatar
The Bone
The Bone is offline
You may be able to rent one instead of buying one for 2 trans swaps.
Old 11-07-2015, 02:21 PM
Tom A's Avatar
Tom A
Tom A is offline
I have a 2000lb. Harbor Freight transmission jack that I've owned for a couple of years and used plenty of times. It's WAY cheaper than buying a "name brand" jack and it works great. It goes high enough to pull the transmission from my lifted off-road rig and it's strong enough to take the cast iron 4-speed, cast iron transfer case, and 1/4" thick steel skid plate all out as one unit.
Old 11-09-2015, 02:20 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Yes anything not made off shore! Would not want to put chineasium junk under a 7K truck or a 500lb trans/xfercase asm, period.
If you presently have or have access to a floor jack several companies make a trans adapter that fits on the end of a standard floor jack converting it to a trans jack. Jegs or Summit will have it. Again no off shore here. You may be able to rent one from a tool rental?
How is your mechanical skills and tool selection/availability? Have you ever performed a trans swap before? There are safety and other standard procedures to follow to ensure a successful swap.
Old 11-09-2015, 02:26 PM
droldsmorland
Yes anything not made off shore! Would not want to put chineasium junk under a 7K truck or a 500lb trans/xfer case asm, period.
How are your mechanical skills and tool selection/availability. Have you ever performed a trans swap before? There are safety and other standard procedures to follow to ensure a successful swap.
EDIT>Tom Im not stomping you. You got your response out before I did. Im a professional wrench as well as conservative and I always try to buy USA just on the principal of keeping this country manufacturing. Ive also witnessed first hand chineasium heavy lifting equipment fail. So its a safety thing for me. So not a dig to you...mostly
No Idea why I have a duplicate post here. I tried to combine or delete the second. Site wont allow it???
Old 11-09-2015, 08:07 PM
Tom A's Avatar
Tom A
Tom A is offline
No offense taken. I'm also a professional mechanic (or was for 25 years before being promoted to Service Manager) and a Conservative. I have a whole toolbox full of Snap-On and Mac tools that I used to make a living with. At work, we have an OTC heavy-duty transmission jack that's fantastic. But when I'm shopping for something I'm going to use at home maybe once or twice a year, $2k isn't in my budget. I bought the Harbor Freight jack because it was cheaper than renting one a few times and I was pleasantly surprised by how well it works. I never get under a load on a jack, anyway, so the worst that's likely to happen if it fails catastrophically is that my transmission may be damaged. I would rather buy American whenever possible but in this case, it was between buying the cheap one and not buying one.
Old 11-10-2015, 07:03 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Those floor jack adapters suck. They are good for filling up the scrap metal pile though.
WP1
Modular V10 (6.8l)
06-18-2013 03:06 PM
ironwood
Modular V10 (6.8l)
01-29-2011 07:11 PM
F250 Super Duper
08-05-2009 11:52 PM
ttaa97
Engine Swaps
07-12-2007 11:19 PM
Supercrewzer76
Modular V10 (6.8l)
06-27-2003 03:17 PM
Quick Reply: Which brand transmission jack to buy? Also any advice on pulling the transmission?
