Mixing Green Coolant with Gold Coolant - **Coolant FLush Results**
That's why I ended up flushing the system myself. After they put Green in and told they flushed it, I didn't trust them. Especially when they said, and I quote, "we remove the old coolant through the degas bottle, by sucking it out".
I told them they didn't know what the heck they're talking about. You can't suck out the coolant through the degas bottle... And I went on to explain why. Ever see that stupid look on someone's face, that's what I got... From their Sr. Master Tech no less.
It takes me the entire day to flush this thing. From the removal of the old coolant by draining the radiator, both block drains (one requires the removal of the starter). Re-fill the system with distilled water, run for 5-10 miles, let it cool. Re-drain the system, add more distilled water, run 5-10 miles again, let cool, drain and finally re-fill with 50-50...
I'm running a coolant filter, I'm planning to open it and see what it looks like. I've had the coolant filter on my truck since it had 10 miles... The first 4 filters picked up quite a bit of material, sand, etc. The last 3 have been perfectly clean.
I haven't met or spoken to one Ford dealer that follows the coolant flush procedure stated by Ford.
