Alternator wiring
Alternator wiring
Does anyone have a simple explanation of the wiring layout on a 79 F250 v8? Mine has the posts on the side I believe rather than the back. My dads also has a 400 and his has the posts on the back. The one wire on mine is melted and ripped off, I have no clue what it is for but it seems to charge. The lights pulse a lot and I think that may be the regulator or possibly the wiring going to it. Like some of the others it too is not in the best shape.
I tried a quick advanced search and so much is related to alt swaps.
The OE alternator on my '78/400 also had rear terminals. I have linked a picture of a Ford 1G case style Powermaster for reference. If you click "360 view" you can see the connections which look same as on my OE alternator.
The big one is the charge wire and the smaller wires to energize and regulate the alternator. From memory, terminal stud size in the smaller wires is different.
I'm not an expert but don't know of any OE 1g alternators with side terminals. Maybe it is a super heavy duty option or swapped.
Can you see an amp rating? Common OE would have been 60 or 65 amp max. My example was rated 40 amps.
Powermaster Street Alternators 17078 - Free Shipping on Orders Over $99 at Summit Racing
My 79 f350 had the side terminal and it has the 351m. The truck was originally a sandwich truck and I assumed it was due to the extra amperage needs that it had a different alternator. Truck has been parted but still have the motor in one unit and can get pics of alternator and wiring harness for that area.
highjack
My 75 f250 390 auto has had an overcharging problem since I got it and no matter what I do it wont go away, yet everything is working right according to digital ammeter. No damage to wiring, multiple voltage regulators tested, grounded to frame, have tried 2 alternators and 2 solenoids. All parts used were tested and are working properly.
highjack
Do you think you have the harness Mike is talking about? Mine is bad several places. If I have to I can probably make a new one or something but I'm open to options.
