wear to start p0016 p0299
P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
Symptoms
Symptoms of a P0016 will or may include:
Causes may include:
Symptoms
- Malfunction Indicator Lamp (MIL) illumination
- The engine may run but with reduced performance
- The engine may crank but not start
- The engine may exhibit a rattle near the harmonic balancer indicating the tone ring is damaged
- The engine may start and run, but poorly
Causes may include:
- Timing chain stretched, or timing belt skipped a tooth due to wear
- Misalignment of timing belt/chain
- Tone ring on crankshaft slipped/broken
- Tone ring on camshaft slipped/broken
- Bad crank sensor
- Bad cam sensor
- Damaged wiring to crank/cam sensor
- Timing belt/chain tensioner damaged
P0299 Ford
Turbo/Supercharger Underboost
– The ECM has detected an error between the expected versus actual exhaust backpressure
Probable Cause[s]
Faulty Injector Control Pressure (ICP) sensor
EGR system fault
Engine mechanical condition -Low oil pressure
Faulty Turbo/Supercharger
Symptoms
Symptoms of a P0299 DTC may include:
Potential Causes
Potential causes of a P0299 turbo underboost code include:
I done lots of reading in all of the forms but fte is wear I go for advice the boys over in 7.3 form know there stuff and are a nice bunch of guys so I come to see what I can find out before I jump in to this this code and other code can they be related
Probable Cause[s]
EGR system fault
Symptoms
- MIL (Malfunction indicator lamp) illumination
- Reduced power output from engine, possibly in a limp mode
- Unusual sounds from the engine/turbo
Potential Causes
- Intake (induction) air restriction or leak
- Failed or damaged turbocharger (sticking, binding, etc.)
- Faulty boost/charge pressure sensor
- Low oil pressure (Ford)
- EGR system fault (Ford)
- Variable geometry turbocharger (VGT) actuator (Ford)
- VGT vanes sticking (Ford)
I would start with the crankshaft position sensor. Check all the wiring.
Also check all the wiring to the PCM.
did you check all fuses under hood and in the kick panel or wherever they are putting the fuses In the cab?
Also the P000 is usually because of a communication error..I think you figured that one out already.
triskit16
10-27-2008 09:59 PM
