HELP!!! its killing me
Old Oct 2, 2010 | 04:37 PM
06f3506.0's Avatar
06f3506.0
ok big problem ill try to make it understandable for everyone. have an 06f350 6.oL i had the motor replaced the new motor has 20,000 miles on it. we used the same intake manifold just cleaned it out same turbo the rest is the new one. ok so i was throwing codes p0069 and p0470 the map/baro and the exhaust pressure circut code. i replaced my map sensor AND my exhaust pressure sensor and i threw the code again now when the cel is on with these codes its hit and miss if my turbo works i can start it drive around everything be fine but only have the cel on and then i can shut if off run in the store real fast come out start it up and no turbo and when this happens i put it in neutral shut it off and start it back up and i have my turbo back. i pulled the sensor i believe to be related to the boost gauge and turbo it is on the front of the manifold right by the oil filter housing i pulled it off cleaned it up and put it back in.. fyi i also have the egr delete kit on. and the only code i should throw with that is one related to the egr but i have a chip to prevent that.
Old Oct 2, 2010 | 05:38 PM
bismic's Avatar
bismic
maybe it is your baro sensor ..... ??
Did you clean out the EBP tube and the MAP sensor hose?
Old Oct 2, 2010 | 05:41 PM
06f3506.0's Avatar
06f3506.0
isnt the map and the baro sensor the same one and yes the ebp tube is clear istarted truck with it off and felt pressure and the map hose seemed to be fine but ill replace it to be safe
Old Oct 2, 2010 | 05:47 PM
bismic's Avatar
bismic
You have a separate Baro - that is why I asked. I believe it is under your dash (inside the cab) on the drivers side.
Edit:
Located inside the vehicle, under the steering column. C2256 is the connector number in the wiring diagram. Tucked up under
the dash.
http://dan.prxy.org/truck/6L_bible_h.../Page_051.html
Old Oct 2, 2010 | 10:10 PM
cheezit's Avatar
cheezit
mark is correct there are 3 different sensors involved. the ebp, the map and the baro.
you really need to look at the values for each sensor and see what one is off. the values should be looked at with the key on and the engine off and should all be around 14.5 +/- .5 psi.
I suspect with the p0470 you issue is with the ebp sensor and or connector.
Old Oct 4, 2010 | 04:08 PM
06f3506.0's Avatar
06f3506.0
my ebp and map are brand new. i can not locate the baro sensor. also i havethe sct X3 pre programed tuner. when i tune it to economy i do not have this problem but i smoke like a chimeny and i loose LOTS of power. when i return it to stock the issue will come back. its really baffling me any help is much appreciated..
Old Oct 4, 2010 | 07:11 PM
cheezit's Avatar
cheezit
Not to be rude I dont care if they are new are not. the does not chage needing to look at the values. theres more to those numbers then new sensors. mainly harness issues.
Old Oct 4, 2010 | 07:20 PM
npccpartsman's Avatar
npccpartsman
AND just because the sensors are new doesn't mean they aren't defective.
iron butterfly
6.7L Power Stroke Diesel
17
Oct 6, 2020 09:08 AM
soberdude94
May 4, 2016 08:56 PM
spudgi
Feb 27, 2016 12:38 PM
Van Diemen
Oct 7, 2009 09:34 AM
