Stiff steering AFTER red head steering box install
Hi, I am brand new to this club and to forums in general, so I apologize if this is the wrong place to put this post. I have learned a LOT from this and similar forums. Although, now I seemed to have hit a roadblock and I haven't been able to find a solution. There are several "similar" posts, but nothing that's hit the mark, so I figured I'd put this out there:
I have an 06 F-250 5.4 gas w/138k. It had recently had a lot of play on the wheel (15 degrees maybe) and last week I made the move to replace the gearbox with a redhead box. All seemed to go ok, but now the steering is stiff and it won't come all the way back to center after a turn. It turns smoothly and completely with no binding, but it has to be moved the last 1/3 turn back to center.
I flushed the fluid initially with Valvoline max life fully syn. Then second guessed myself after the problem started happening so I switched it back to regular Mercon. No improvement.
I had it on stands today and it was extremely difficult for me to turn my tires left to right manually (at the wheel). The only other thing I did was adjust the sleeve on the drag link to straighten out the steering wheel.
Should I be able to turn the tires left and right from the wheel easily? Every now and then I hear a wine from the pump which I never had before, but 99% of the time it seems fine and is quiet. it just feels like something is over tight but everything should be to spec. Has anyone ever had to swap out a redhead steering box? Any thoughts?
I agree that the box is probably not adjusted properly.
If you have a 4x4, another possibility I have ran into is seized outer u-joints. I replace almost the entire steering system in my Ranger before I found the problem. But if you were not having the problem before the steering box install, then I would put my money on the box.
Hey guys, just wanted to give you an update. I reached out to Red-Head and we went through some troubleshooting. They determined it probably was the box so they shipped me out a replacement. After I swapped out the box the steering feels great! Thank you for the advice which pushed me to call.
Wizkid, I did have a u joint issue prior to all this. I had the steering problem that other people have experienced where the truck would move left to right and the steering wheel was impossible to keep in the middle. I greased the crap out of the joints and locked the hubs for a week to get the grease worked in. Since then there have not been any problems.
Thanks again for the input!
dakeddie
08-23-2017 02:26 PM
ford351c
05-19-2003 10:14 PM
