halogen 6 volt headlights
Typically battery and ground cables are junk after a couple decades and should all be replaced. Grind down boss connections to bright shiny metal and tighten securely. Charging systems, generator or alternator do not like high resistance in the circuit. Headlights have a "strike" or minimum voltage they require before they will operate properly, brightness drops off quick at anything below this figure.
Also, if the headlights are dim, then the ignition and accessories will be "dim" as well. The charging system "sees" excessive resistance as a battery that needs charging constantly. These old trucks will have corrosion problems after these many years and it takes a little effort to get them back to OEM levels. Restored trucks often have similar issues, though with thick paint performing interference duties.
Shiny connections = Happy electrons
clark grizwald
07-24-2017 03:58 PM
fifty-two_f1
13
07-03-2012 01:59 PM
CrazyFordMan
01-28-2004 01:28 PM
