my dim 6 volt headlights
Old Jul 20, 2017 | 03:00 PM
clark grizwald's Avatar
clark grizwald
I cant see for S#&T at night, wondering where to get a brighter set of headlights for a 6 volt system? led?
Old Jul 20, 2017 | 03:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's more likely that you have wiring problems (bad ground?) or your system voltage is low. Other than at idle, they should be as bright as 12v tungsten headlights.
Old Jul 20, 2017 | 03:59 PM
bigwin56f100's Avatar
bigwin56f100
I wonder if you have 12 volt bulbs in a 6 volt system?
Old Jul 20, 2017 | 05:19 PM
abe's Avatar
abe
All the above are good points. They also make 6 volt halogen bulbs. I bought mine at NAPA for about.... I think.... about 16 bucks each.
Old Jul 20, 2017 | 09:53 PM
jniolon's Avatar
jniolon
old and in the way
i agree with Ross... check the wiring, especially the grounds... lots of rust = voltage drops
Old Jul 20, 2017 | 10:12 PM
Rust Wrangler's Avatar
Rust Wrangler
A six volt headlight should be as bright as a twelve volt one. Check voltage at the headlights with the lights on to make sure you're getting a full six volts there. Besides bad feed and ground connections a crusty dimmer or light switch can be a cause for low voltage also.
Old Jul 21, 2017 | 05:58 AM
big job's Avatar
big job
I would start at the dimmer switch. Usually the middle terminal come from the head lite
switch which should have good vts check the other two thats high and low beam should
be good volts if not dimmer is bad, if good next remove seal beam check each side of
the plug thats high & low volts should be as good as the dimmer test if not something
wrong with wires from that plug to the dimmer (most likely bullit connectors all green
corrosion) Then on the bulb plug, test the ground terminal that usually is the wire screwed to the bucket to fender, should be good if week then test the fender for ground. Or get a jumper & jump that grd. wire to batt. ground put bulb back in is it now bright? If you notice all newer
vehicles the radiator support has a ground wire.
Old Jul 21, 2017 | 10:01 AM
clark grizwald
Thanks for the feedback! I recently put new halogens in so i'll start checking the voltage....
Old Jul 23, 2017 | 11:24 PM
Jag Red 54's Avatar
Jag Red 54
I have had 6volt halogens in my 55 Fairlane for years. They are much brighter, but they draw the battery down at idle.☹️ Jag
Old Jul 23, 2017 | 11:43 PM
abe's Avatar
abe
I heard they use less power than regular headlights.
Old Jul 24, 2017 | 11:45 AM
clark grizwald
I would lean towards more current because the voltage is half, and if they are as bright presumably the power output is the same (based on comments above) which would require double the current (E x I =P)
Old Jul 24, 2017 | 03:58 PM
Jag Red 54's Avatar
Jag Red 54
Halogens are very bright, but power hogs. If you want to lessen the power demands, you'll need to go LED. Jag
abe
16
Oct 19, 2015 04:23 PM
74baja
Jun 27, 2009 12:49 PM
kawboss
1997 - 2003 F150
36
Apr 15, 2008 08:44 PM
hoxiii
Sep 5, 2006 12:19 PM
BlueDolphin
Jul 31, 2005 12:01 AM
