Ok to park it for the winter ?
It is possible, but there are a lot of variables to consider.
First thoughts...
Covered / uncovered?
Insulated or uninsulated?
Are you able to start & drive periodically to get engine to normal operating temp?
If so, good (once per week - bi monthly). With expected maintenance it shouldn't be a problem.
If not, do you have access to power for trickle charger or do you plan on removing batteries?
DEF consisting of roughly 67-68% water has a freeze point around 12F.
Is location secure?
Other considerations...depending on answers to above
all fluids sitting idle that long? seals drying out?
condensation in fuel?
tires sitting that long in same spot?
depending on location, we've had plastic crack if gotten too cold (a newer model Tahoe in SC winter)
These are quick thoughts....other's will definitely have more. I drive a company car M-F, but make sure to drive truck each weekend to keep all working properly.
First thoughts...
Is location secure?
I have parked mine from November to April for the last 2 winters (since I bought it new in June 2013).
I put a Battery Tender on it, use Sta-Bil for diesel and fill the diesel tank.
It sits in the garage all winter. I do not start it.
Starts almost as easily in the Spring as it does during the year.
No issues so far.
No issues so far.
on
No issues so far.
No issues so far.
parking for the winter
I sometimes let my trucks sit for extended periods of time
I put ford anti gel in it and pack it with as much fuel as possible
I make sure it has fresh oil in it
Check and adjust tire pressure
clean it inside and out
I have one of those mice things that emit noise under the truck
I don't do anything else to it
It sits in a garage for months
when I decide to drive it it fires right up
I have done this with the last 4 trucks and have never had any issues
YOU COULD: put steel wool in the exhaust prevents critters from moving in
disconnect batteries & hook up a tender
jack it off the ground without letting suspension hang
Just write yourself a little checklist so you remember what you did so you don't start it with steel wool in exhaust or something silly like that
I do that to some of my stuff in the off season and it works
97C5ENVY
6.4L Power Stroke Diesel
11-18-2010 08:46 PM
A H DEVELOPMENT
1999 to 2016 Super Duty
31
06-02-2010 06:40 AM
bhansen198
General Diesel Discussion
08-12-2006 07:50 PM
