99-2004? Difference between Automatic and Manual BARE CABS
Hello All Ya'll
So the old girl is in need of some new metal. Cab corners are gone, rockers are starting to go, the rest of the floor isn't long for the world, and the roof has hail damage dents all over it. Got a quote from a body shop that I trust for 3500. He uses really thick replacement panels, but still....not in the budget.
Besides, the truck came from New York, and is VERY rusty. I just can't see putting money into that cab. It's just too far gone, IMO.
So I'm planning on making a run down south (east coast) to find a cab.
Car-Part.com lists all the different varieties....super cab, regular cab, and crew cab....those differences are obvious....but what are the real world differences between 4wd vs 2wd.....or auto vs manual?
I know in dealing with the older stuff (90's), the cabs were all the same, but for the plates in the floor.
I couldn't for the life of me imagine, that Ford would make a totally different cab for ONLY 4wd or ONLY automatics. Maybe I am overthinking this. The automatic cabs are a lot more common. That's mostly my dilemma.
FWIW....mine is a 2003 super cab, 5.4L, 4wd (ESOF, not stick on floor), 6 spd manual; and I am in Pennsylvania.
I can guarantee the floor pan is different between auto and man trans. You will not get an auto floor pan to fit the manual; the zf6 is much taller! For electric shift 4x4 there is just a cover plate that is on the cutout for the lever so those are the same floor. The pre 99 had a modular floor you could change the cover plate on depending on trans, not super duty
This where I got a replacement cab for my 04 F350. http://www.coutus.calls.net/
The cab came from Georgia and is rust free. If your close to Willimantic, CT it might be a shorter trip then going down south.
The whole entire floor is different, then? Mostly where the transmission hump is, but way too different to interchange? There is not just a different metal piece that covers the hump.....like the old days?
It wouldn't surprise me that's how they are. Why would anything be easy.
Not what I wanted to do, but I could cut my current manual hump out and put it in the auto cab. Couldn't imagine that part is too awful rusty.
Any of the auto-manual swap guides you find online show that you just need to cut and put the taller hump in. I've done extensive research on the subject as when/if my auto goes a zf6 will be going in to replace it.
Here is one such example:
http://www.powerstroke.org/forum/99-.../113385?page=1
I love driving standard, and while I don't like the cost of the swap I love the idea of it.
Good luck with your swap,
Nate
Nate
I updated my original post, didn't mean to come across so snarky. There are plenty of guides out there that show just how people cut, etc. I think the one I posted the pictures have disappeared, I can look for a guide with pictures for you when I am not on mobile as I have quite a few saved on my desktop browser, it is really a lot less daunting than it sounds.
Cheers,
Nate
Cheers,
Nate
Tazmax 1975 High Boy
10-01-2012 10:56 PM
smkulas
04-07-2012 12:12 PM
