Cab swap
Old Feb 10, 2019 | 11:42 AM
Technasty13's Avatar
Technasty13
Cab swap
I have a 96 f150 super cab 6 300 2wd automatic. I'm wanting to place my cab on a 92 f150 super cab 4x4 manual. Will the cab clear/fit over the new tranny? Any insight would be greatly appreciated.
Old Feb 10, 2019 | 01:33 PM
bbf385's Avatar
bbf385
Remove the carpet and you will see the trans tunnel in the standard truck is removable. If the auto truck also has a removable panel you are good to go, just use the manual cover after the swap. If the auto truck doesn't then just cut out the hole in the floor and use the cover from the other truck. Other than that don't lift by the roof.
Old Feb 10, 2019 | 01:37 PM
Technasty13
Is the "hump" the same size on both cabs? The reason I'm asking is I was looking into a carpet kit for the pickup and they made it seem like there was a difference other that the holes for the shifter and such...
Old Feb 10, 2019 | 01:40 PM
bbf385's Avatar
bbf385
the cover for the standard is a bit taller, yes
Old Feb 10, 2019 | 01:47 PM
Technasty13
Ok thank you. Do you know if the steering column and clutch pedal will "bolt in" without any serious modifications? My understanding is that all cabs are generally the same from the factory just set up for different applications?
Old Feb 10, 2019 | 01:53 PM
bbf385's Avatar
bbf385
yes. 100 % bolt in and easy to do.
Old Feb 10, 2019 | 02:06 PM
Technasty13
Thank you for your replies
ss27gogeta
13
May 25, 2019 09:24 AM
fsbronco1989
Sep 15, 2015 08:56 PM
michaelleiterman
Oct 30, 2014 12:46 PM
jbulson
Dec 1, 2003 05:18 PM
bocky65
Jan 1, 2003 07:04 PM
