Door lock issue
Door lock issue
hey everyone, So I have a 2005 F250 with some door lock issues. I don't this has to do with the resistor or anything. My issue seems to be different.
On the drivers side the door will not lock when you push the button or fob. It tries to lock, but something is holding it up. So I went with the key, while it will lock with the key the key will not come out of cylinder. It will only come out when the key is slightly turned to about 20 deg. So I stuck the key in turned it so it is straight up and down. Even though it wouldn't come out and tried the fob and button. It locked, but I need to turn the key 20 deg to have it come out so it is enough to unlock it.
Make sense?
Anyone have this issue?
Thanks
Make sense?
Thanks
deerslayer joe
09-21-2009 07:56 PM
