1993 f-150 acts like it's not getting enough fuel on rear tank
I have a 1993 F-150 5.8L 4x4 and when i use to the rear fuel tank the truck can start and idle decently, but when i step on the accelerator it starts to sputter and act like its fuel starved (the effect magnifies the more i press on the accelerator). The truck runs perfectly fine when i'm using the front tank though. From what i can find it seems the truck only has one fuel filter that filters both tanks so i doubt its that since the front tank works fine. My guess is the rear sending unit is weak or clogged up?
Im guessing on this one however so any help would be appreciated.
I switch to rear and it idles at 26 psi peak and spuds lower often... and when i accelerate it drops way down to below 10 psi and it sounds kinda like its sucking bubbles and air when i put my ear close to fuel intake. Any suggestions yall?
I tested the pressure and front tank is normal 38 psi idle and 40+ ish under load.
The other side effect is it can cause low pressure from the good pump because the running pump is providing fuel to the engine while it is also filling the other tank. Make sure the front tank is not filling up with fuel from the year. If it is not "gaining" fuel level then you most likely have a bad rear fuel pump.
Could be a bad rear pump. These trucks have a high pressure pump in each tank. Each Fuel Delivery Module has a check valve to prevent the running pump from back filling the unpowered tank. This internal valve is known to fail which causes the unused tank to fill up with fuel.
dziwei
06-15-2018 08:53 PM
cornbinder
11-12-2010 10:29 PM
