pre-bent brake lines?
Does anybody make pre-bent brake lines for our trucks,more specifically my 1996 f250? The line that goes to the front driver's side is rusted out and leaking,and it has 3 or 4 coils at the master cylinder. Was thinking it would be nice if I could just find a pre-bent line and not have to replicate the coils. Thanks!!
Pre bent Brake Lines by Classic Tube
Homepage
I used them for the transmission lines. I bought the pre-bent stainless steel set. They came to the house as specified and installed as they should. I suspect the brake lines are of similar quality. The picture below is the line running to the rear brakes. I fabricated this myself and replaced it.
Received 3,107 Likes
on
i will never ever use steel lines again. every brake line i have replace in the past 10 years has been done with the nickle/copper alloy lines. they bend by hand, and can be unbent if you make a mistake without kinking. plus they are the same price or a little cheaper than steel lines.
i used to have to replace brake lines on my trucks every 2-3 years at the most, and since started using the alloy lines 10 years ago, i have not needed to replace one of the yet. a
