F250 Auto Trans Upgrade
It wouldn't be a very good idea to have a double OD, all the stress on the trans with the 2x gear down would cause tons of heat, and obv heat=trans death
Except that it wouldn't cause any more heat. Heat comes mostly from slipping the torque converter. As long as the torque converter is locking you won't have any more heat. If it is unlocking you ought to be shifting out of at least one of the overdrives.
Yes that's what I mean, with such a high ratio you would have to make sure the torque converter is locked, at that point it seems to defeat the point of having the double OD setup because most of the time the GV OD would be used, the trans would be locked out of 4th. I just don't see how the few times you would use it would make that much of a diff with mileage or wear and tear
Now that truck could never have pulled two overdrives, but switch to 4.10 gears, 31" tires, and a diesel and you're up to 1900 rpm at 60 mph. A second overdrive would bring you down to around 1500 rpm (assuming the Gear Vendor has about an 0.78:1 OD, I don't know what it really is).
So would it be a good choice in most situations? Probably not. But it could work out well in some relatively common ones.
brucemdye
13
02-25-2007 07:47 PM
kaufmanlawn
03-16-2006 04:49 AM
javi2001
08-20-2003 06:01 PM
